It is currently Thu Jan 18, 2018 3:12 am
PostPosted: Thu Oct 19, 2017 5:17 am
Hi guys
I upload the backup from a PV550 DH+ old terminal through RS232 printer port and a straight cable. No problems with the upload, I got the .PVA file.
When I tried to convert this to .PBA, the PanelBuilder32 showed up "Cannot Load External Font Server".
The existing PV550 has a memory card inserted.
The problem is: the existing PV550 is in a bad condition, we have another one in stock (exactly the same PV550)
1- If I download the .PVA file from the old PV550 to the new PV550, will it run without problems? (Even if I dont put the memory card on the new PV550)
2- Do I need to remove the memory card from the old PV550 to the new PV550?
3- Is there any way to get the external font and add it to my panelbuilder32 so I can open and modify the application?
Thanks in advance
Users browsing this forum: Bing [Bot] and 7 guests
