It is currently Fri Feb 23, 2018 1:43 pm
PostPosted: Tue Sep 19, 2017 1:04 pm
Hi , I am the new in AB controllogix redundant. The project use PLC Allen bradley L-71 CPU redundant and there are remote ios via ethernet ring. I faced the problem that when the cpu switched from Primary to Secondary, output signal on the remote io rack will lost for a while and after 2 or 3seconds that remote io output will recover.
Has anyone have any suggestion?
Thank you in advance.
Users browsing this forum: No registered users and 5 guests
