It is currently Thu Oct 18, 2018 5:36 pm
PostPosted: Thu Jun 01, 2017 5:08 am
Hello all,
has anyone else had an issue trying to right click configure devices from the rswho screen and it be stuck on configure remote devices via linx gateway for that specified driver?
I've tried this for DF1 driver and 1784-U2DHP driver yet it still pops up with this tcp driver even though I'm not using and its not in the configure drivers screen.
Under communications > Configure Gateway I have enable RSLinx Classic Gateway unchecked.
When I try to use rlogix500 and goto comms > whos active go online > and select my driver to see whose active on the dh+ network it says the same configuring the settings to a linx gateway is not allowed. add a new tcp driver ("remote devices via linx gateway") in rslinx classic and then select your path through the driver.
never had this happen before I updated to 2.59, tried 2.57 and 2.58 but the issue is still there.
thanks for any help
PostPosted: Fri Jun 02, 2017 5:00 am
Figured it out if anyone else has this problem, delete the 2 harmony files for rslinx.
