It is currently Thu Jan 24, 2019 4:27 pm
PostPosted: Thu Jan 05, 2017 4:00 am
Hello every one.
Some one can help me, posting a link to download Studio 5000 any version it is good.
Regards.
PostPosted: Fri Jan 06, 2017 4:14 pm
Asolis wrote:
Hello every one.
Regards.
Try it!!
ftp://tehna-lj-gw.amis.net/Studio5000/
:haha:
PostPosted: Mon Feb 20, 2017 12:18 am
hi.I would like to download the studio 5000, but the link do not work.
PostPosted: Mon Feb 20, 2017 6:20 pm
Try it! (suc)
https://mega.nz/#F!Nxo1EKJQ!GTL7loUdjVWNBQ4BdbdGSQ
PostPosted: Fri Mar 03, 2017 1:25 pm
What license to use in the software in the links?
PostPosted: Mon Mar 13, 2017 12:43 pm
https://mega.nz/#F!Nxo1EKJQ!GTL7loUdjVWNBQ4BdbdGSQ[/quote]
Good morning,
I followed the instructions as close as i could for V29. I can edit files but when i try to create a new file it crashes and displays this error. "Unable to load logix designer: failed to initialize factorytalk activation ( error code 8 ). there are several files im not sure what to do with.
can anyone help me please.
PostPosted: Mon Mar 20, 2017 8:21 am
Good morning,
can anyone help me please.[/quote]
Hi Tacocat,
I am downloading and will try later but I found "HOSTDISK_SERIAL_NUM=265F3E19_Concurrent_20140430025452571.lic" in ver.19 also. Have you tried putting it in C:\Users\Public\Documents\Rockwell Automation\Activations as last step in instruction.txt ?
PostPosted: Wed Aug 23, 2017 8:05 pm
Hi .. any update sir??.. i try to installed v30. ..but when i try to create a program an error appeared afinfo.dll not found can you please help me how to fix it. ..and how to activate factory talk activation manager thanks in advance ....
PostPosted: Sun Sep 03, 2017 6:31 pm
Dear Mr T-Jay,
Refer here, maybe useful for you.
http://fake/19-vt31.html?post ... &start=270
Regards!
PostPosted: Tue Sep 05, 2017 3:46 am
Thanks you sir. .
PostPosted: Tue Oct 31, 2017 9:44 pm
Good morning,
Hi Tacocat,
I'm stuck in the same situation. Did you succedeed in any way?
PostPosted: Tue Nov 07, 2017 5:23 pm
Hello every one
I just install normally and everything works well.
About the license, I just reset the factory talk activation manually
engr_kierrosita
Good luck
PostPosted: Tue Dec 19, 2017 4:41 am
Hello all,
Anyone with info. on how to activate Studio - Logix designer v30 please?
The link provided by "pipikikiki" below doesn't seem to be working anymore as it takes me to a login page that doesn't accept my login credentials.
Dear Mr T-Jay,
http://plc.fake.ro/19-vt31.html?post%20...%20&start=270
Regards!
Help much appreciated!!
(tyou)
cntrlmation
PostPosted: Fri Jan 12, 2018 12:52 pm
engr_kierrosita
Good luck
What does mean "reset the factory talk activation"?
FT activation manager does not contain items like "reset activation".
how exactly do it?
PostPosted: Sun Mar 04, 2018 8:12 pm
pugacz wrote:
engr_kierrosita
Good luck
how exactly do it?
just reset activation manually
(ev)
PostPosted: Sun Aug 26, 2018 11:23 am
Lamatrian wrote:
Good morning,
Hi Tacocat,
same situation here. any luck?
