It is currently Tue Apr 24, 2018 5:27 pm
PostPosted: Sun Jul 31, 2016 2:17 pm
Dear friends,,,
How can activate RS Studio 5000 vr.26.
Please help me.... (sbutton)
(wow) (wow)
PostPosted: Mon Aug 01, 2016 10:21 am
Downloads: https://mega.nz/#F!R8YkyaCD!nFduaj3iPkwfhlkFvPmM6Q
https://mega.nz/#F!p5RgDA7a!W_nIAW--bl91jST5MhCDhg
Install version 26 normally.
after installation is complete uninstall factory talk activation and install a version that is crackable with the binaries in the download link (IE: version 3.62, 3.60 or 3.51)
Restart windows in safe mode
Copy the cracked binaries to the correct path by following the read me's in the files
Make sure you copy the corresponding version with what version you installed. These are not interchangeable.
Once you have copied all files to their correct path restart pc and check activation.
You will have to search around for a way to get rid of the message because i don't think i have the FTASTUB.dll for version 26. doesn't hurt anything just kind of annoying
(END)
SECOND OPTION:
You could also use this license that i believe i found originally on the other forum. Its a legit license file just change your serial number to the one in license file with the hard disk serial changer i provided in your other post. You can only do this if you don't have other legal licenses activated on this pc because they will no longer work after changing serial number unless they are ties to the mac address of your network card.
https://mega.nz/#!514GSI4K!8JE-uv4SgC4g ... WAzfos2SfM
PostPosted: Fri Oct 07, 2016 9:13 am
hi everyone,
need help
I try to patch flexsvr.exe but dialogue box pops up and "read only" file how can I edit it using hex edit?
thanks for the help
PostPosted: Sun Oct 09, 2016 1:24 pm
HI EVERYONE,
HOW CAN I PLEASE DOWNLOAD Logix Designer Studio 5000 V26.01
THANKS IN ADVANCE
PostPosted: Sun Oct 30, 2016 11:40 am
This method worked for me for Studio V24 just by following your 3 steps.
My FTAM V3.62.11
But it says the License will expire on 1/1/2017 in License manager.
Thanks very much for sharing this.
Is there a way to extend the expiry date?
cron
