Rslogix 500 msg instruction
Binary01
Post by Binary01 » Wed Sep 02, 2015 8:24 pm
I am new to using the rslogix 500 msg instruction, I am getting problems setting it up.
I have two a slc 5/03,s connected to ethernet via 1761- net eni, both devices seen on rs linx.
I want to have an input triggered in one plc and the output come on the other plc, after then i will try the communications monitoring (heartbeat) setup(with help from this site.
On the message instruction I configured:
Read/write: Write
Target device: 500 cpu
Control block: N7:0
SETUP SCREEN
table address: N7:0
size element: 1
channel: 0
target device
timeout: 5
table address: N7:1
Node: 0
No success, I got this message on the setup screen: no ip address configured on network.
Can I get some pointers please?
