I am new to using the rslogix 500 msg instruction, I am getting problems setting it up.
I have two a slc 5/03,s connected to ethernet via 1761- net eni, both devices seen on rs linx.
I want to have an input triggered in one plc and the output come on the other plc, after then i will try the communications monitoring (heartbeat) setup(with help from this site.
On the message instruction I configured:
Read/write: Write
Target device: 500 cpu
Control block: N7:0
SETUP SCREEN
table address: N7:0
size element: 1
channel: 0
target device
timeout: 5
table address: N7:1
Node: 0
No success, I got this message on the setup screen: no ip address configured on network.
Can I get some pointers please?
Rslogix 500 msg instruction
Return to “Allen-Bradley (Rockwell Automation)”
Jump to
- International User Forum
- ↳ SIMATIC Automation
- ↳ SIMATIC system
- ↳ Utilites for Simatic PLC
- ↳ Siemens SIMATIC HMI
- ↳ SIMATIC HMI
- ↳ Utilites For simatic HMI
- ↳ OMRON
- ↳ OMRON PLC & HMI
- ↳ Utilites
- ↳ Allen-Bradley
- ↳ Allen-Bradley (Rockwell Automation)
- ↳ Utilites
- ↳ other PLC
- ↳ Other PLC
- ↳ Utilites
- ↳ Other HMI
- ↳ Other HMI
- ↳ Utilites
- ↳ Drivers and Inverters
- ↳ Sensors
- ↳ Industrial network
- ↳ samples
- ↳ Siemens Hardware & Software
- ↳ PLC`s Videos/Audios/Books & Over Manuals
- ↳ PLC's video
- ↳ PLC's books
- ↳ Other Books
- Russian User Forum in Russian
- ↳ Simatic (Russian)
- ↳ Simatic HMI (Russian)
- ↳ Other PLC and HMI (Russian)
- The Near-PLC Themes
- ↳ About forum , files exchangers and RULES
- ↳ Other (only about CAD and Soft)
- ↳ JOB
