rslogix 5000 v20.01 or higher
jiwidi
Post by jiwidi » Wed Feb 04, 2015 7:00 pm
Hi , i need to download the version 20.01 or higher because the 19 doesn´t open my old files , someone has any idea of where i can download it with crack? or serial/keygen.
Thanks.
NowanH
Re: rslogix 5000 v20.01 or higher
Post by NowanH » Fri Feb 06, 2015 3:15 pm
jiwidi wrote:Hi , i need to download the version 20.01 or higher because the 19 doesn´t open my old files , someone has any idea of where i can download it with crack? or serial/keygen.
Thanks.
If you want to open an old application, you need to search for an old RsLogix. I mean, higher versions of RsLogix can't open old version files.
When you have several versions of RsLogix installed on your PC, you can upgrade the version of any project (if you have the original and final versions of RsLogix)
psgama
Post by psgama » Fri Feb 06, 2015 8:32 pm
You need to install rslogix 5000 versions 16-20. You must have the firmware version installed for the version of file you are trying to open. You're probably just missing the one version the file is created with. Studio 5000 v23 and 24 is unlikely to be cracked and released by anyone in the scene any time soon. The executable and dll files are custom packed. They check for CRC, and they are digitally signed. The license daemon also seems to be either packed, or virtualized. So, it would be quite time consuming for someone to crack the licensing from what I can tell.
jiwidi
Post by jiwidi » Sat Feb 07, 2015 7:37 pm
have someone the version 20.01 exactly? i created a file with this version on univeristy and now i can´t acces the program , i will pay 50 euros to the one that give me that version
kna1512
Post by kna1512 » Wed Feb 25, 2015 10:05 pm
Dear all
Is there anyone who can help me to activate studio 5000 v21.00.03 and Emulate 5000.
I have read almost all the notes. some of which are not understandable to me probably because I am not a software expert. I really appreciate all the incoming feedback.
Thanks in advance
kna1512
Post by kna1512 » Fri Feb 27, 2015 3:46 pm
kna1512 wrote:Dear all
Thanks in advance
I have been using various information from this forum to active studio 5000. Thanks to all those who contribute something useful in this forum. My problem is now that I get an error message as shown in below. It would be nice of you who know about the problem and will share his experience with me.
Fatal Error!
Application Path: C:\Program Files (x86)\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\LogixDesigner.exe
Elapsed execution time: 26 seconds
Version: V21.00.00 (Release)
Source File: unknown
Line Number: -1
Function/Method: unknown
OS Version: Unrecognized OS 64-bit ( - Build 9200)
Thread Id: 00000604 (1540)
Error 0xc0000005 (-1073741819)
EXCEPTION_ACCESS_VIOLATION - An "access violation" exception was generated.
No project file is currently open.
psgama
Post by psgama » Fri Feb 27, 2015 5:05 pm
You edited something wrong in the Studio 5000 folder, either FTAStub.dll or logixdesigner.exe
Restore your dlls back to original and try running the program to make sure it pops up with the non licensed pop up again and start over with your hex edits
