Access Softlogix V16 from a Different PC ?
Tensaiga
Post by Tensaiga » Thu Nov 20, 2014 7:51 pm
Hello, I would like to know if we can have the Softlogix V16 software installed on one PC, and and using another PC with RSlogix5000 installed to remote upload/download inside a private corporate network? If I use the virtual back plane that only allows the current PC to go online, and if I tried too use the Ethernet IP devices then only the PC shows up as a node, RSLink can't see the controller nor it's Ethernet port? Any thoughts on if this is possible to do?
Thank You!
