Factory talk view studio 7 activation
yasi
Post by yasi » Tue Sep 17, 2013 9:12 am
Hi!
How can I activate FTView 7. There are two license files in the activation folder and what should I put there? . According to previous activations I managed to activate FTView 7 studio But when I launch SE client mode it displace a message like " HMI server is running in grace period".How can I activate HMI server and what files should I edit using hexedit ? These all files are in RSView Enterprise folder.So if anyone can activate HMI server or RSView Enterprise Please help me......
Thank You!
(fback)
yasi
Re: Factory talk view studio 7 activation
Post by yasi » Tue Sep 17, 2013 8:13 pm
Hi!
I found the solution.I just added below lines in the license file and problem solved. :D
FEATURE RSVSECLI.RO flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSVSECLI.RO" SN=0000000001 \
FFFF FFFF FFFF FFFF"
FEATURE RSVSECLI.RW flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSVSECLI.RW" SN=0000000001 \
FEATURE RSVSE.MAX flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSVSE.MAX" SN=0000000001 \
markdeleve
Post by markdeleve » Wed Apr 02, 2014 6:17 pm
Hi!
I've tried to add these lines to my .lic file but it didn't work.
Do you know anything new?
Thanks a lot...
henryduyle
Post by henryduyle » Fri Aug 08, 2014 5:29 am
Thank you so much (pgood)
aymeric38
Post by aymeric38 » Tue Jun 07, 2022 8:25 am
Hi!
Thank you very much sir, works perfectly !!
Cristiano14
Post by Cristiano14 » Sat Oct 14, 2023 10:40 pm
I'm looking for Factorytalk View Studio Site Edition v9.00.00, does anyone have it? Can someone help me?
Thanks!
