It is currently Wed Jan 16, 2019 10:09 pm
PostPosted: Thu Feb 13, 2014 10:38 pm
I have tried several times to activate the RSLOGIX500 software including starting from scratch:
am I missing something here ??
I edit the Hex edit 34 02 at FC339
I have added the following to my Factory Talk
Code:
FEATURE RS500P.exe flexsvr 1.00 permanent 10 VENDOR_STRING=9999999 \
 HOSTID=ANY vendor_info="PRODUCT_NAME:RSLogix 500" SN=0000000001 \
 FFFF FFFF FFFF FFFF"
And each time I run the program I get
"Fatal Error !
The copy protection licence for the application could not be acquired Error:2"
What gives ?? All my other stuff works fine.
Ok I found that Factory talk had made an *.rnl file located :
Code:
Users\All Users\Rockwell Automation\Factorytalk Activation
I removed those files (*.rnl) and under my Factory talk Activation Manager I refreshed the server.
This recreates the *.rnl file and now my RSLOGIX500 came up with a 7 day notice "This product has not been successfully activated".
I will check my wording in the activation file.
I have verified the Factory Talk TXT Activation file and it looks correct.
PostPosted: Thu Mar 20, 2014 3:04 am
Hi Ronnie, the license file is for rslogix500 pro, serial # will need to be 1014123456 or any #'s after 1014 up to 10 digits.
Regards
PostPosted: Tue May 20, 2014 7:40 pm
Regards
I did the above and I am still not getting full activation just a 7 day expiration notice.
PostPosted: Tue May 20, 2014 8:12 pm
OK working now.
Here is what I did: Use the Serial above, then edit the Activation file and added the same Serial number in there, then I tried running the software and I got the 7 day notice.....
I then Hexedit the file and changed FC339 Hex 3402 to 3090
Saved and restarted RSLOGIX 500 V9 in Windows 7.0 and it works..... :shock:
PostPosted: Tue Feb 24, 2015 2:20 pm
I am still having problems with activation.
Can you please give me step by step instruction on how to activate it.
I have followed the instruction found but I was not able to activate.
Any help would very much be appreciated.
Thank you.
PostPosted: Thu Feb 26, 2015 8:28 pm
http://e10000.cn/a/a.asp?B=305&ID=1381406
PostPosted: Wed Aug 12, 2015 7:00 pm
Hi!
Please, could you give me a link to the program RSLogix 9.05?
I really need this program!
Thank you very much!
PostPosted: Thu Jul 21, 2016 6:49 pm
Ronny_Resistor wrote:
OK working now.
Worked for me too, it was driving me crazy, on the front of the machine and coudn't open the program before using your tip.
Thank you man!
Code:
FEATURE RS500P.EXE flexsvr 1.00 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLogix 500 Pro (English)" SN=1014123456 \
PostPosted: Fri Sep 09, 2016 3:32 pm
Sorry I have been searching but I have found nothing, which is the file you have to hexedit?
Thank you.
PostPosted: Sun Sep 25, 2016 11:43 am
Thank you.
PostPosted: Thu Feb 09, 2017 5:15 am
OK working now.
hi,ronny,at first i must say thank you! I solve the problem of activate rslogix 5000 V20 (http://www.plctalk.net/qanda/showthread.php?t=72171&page=2)
now,I‘m trying to activate rslogix 500.I've add the following Code to this path“C:\Users\Public\Documents\Rockwell Automation\Activations”,just as you said each time i run rs500.exe, a 7 day notice "This product has not been successfully activated" coming. You said “I then Hexedit the file and changed FC339 Hex 3402 to 3090”,which is the file you have to hexedit and how to edit this file?I can't understand you answer exactly for I'm not good at both english and rslogix500 .thanks !
Code:
PostPosted: Sat Feb 25, 2017 8:16 am
Dear All
Can any one help me by uploading RSLogix 500 Version 9 please ?
PostPosted: Fri Mar 10, 2017 4:51 am
Dear all,
I coudnt find de .lic file.
Could anyone explain? Thanks!!!
PostPosted: Tue Sep 26, 2017 11:30 am
OK working now.
what file I need to change with Hexedit? please help...
PostPosted: Tue Feb 20, 2018 1:13 am
Hi All,
it's not easy to get a reply on this forum anymore , it's sad.
PostPosted: Tue Feb 20, 2018 5:38 am
C:\Program Files\Rockwell Software\RSLogix 500 English\RSwl032.dll
