Hi people.
I've tried to active my RSLogix5k, but the factury talk activation don't run.
Could anyone help me???
thanks!
[?] RSLogix5k V20.01 In Win 7 Ultimate 64 bit
Re: [?] RSLogix5k V20.01 In Win 7 Ultimate 64 bit
you can download from......
http://www.2shared.com/file/DmJxLioj/ABHexFile.html
I have tried it, key working properly......
Dedy aiza, I've tried this, but the factury talk activation don't run. It is always in stopo mode.
I think it is my win 7 ultimate 64 bit, qhat do you think about it?
If you have RSLogix5k activeted in win 7 ultimate 64 bits, could you send me the rsl5kcp.dll and ftasystem?
thank you very mach!!!
Hi helder,
I am also use win7 ultimate 64 bit, RSLogix 5000 v20.01 working and successfully try simulation using emulator 5k v20.01
First you must copy and paste ftasystem.lic to C:/users/public/public documents/rockwell automation/activations
and then you can follow step readme.txt file on abhexfile , copy and paste(replace) .dll file
try to disable anti-virus firewall, then manually start server in factorytools/advanced
it should work!
it should work!
Hi, I need to activate rs5000 v20.00. I read this post and found the ftasystem file in a correct folder. I follow this link http://www.2shared.com/file/DmJxLioj/ABHexFile.html but I could not find readme and ABHexfile. Can someone post them and guide me to install.
Thank you very much in advance.
I got it working now. Thank all for posting this
