i need help,RSlinx 2.58.00.15 CPR 9 SR 4 activation problem.i tried other activation key but it did not work.
help me please
Yes, I press Download button and error appear .peterg70 wrote:link is good just test it
make sue you press the correct download button
luke12faulin wrote:Hi, Proeng
I just copied my edited file for AB FTA
you can downloaded at http://www.2shared.com/file/DmJxLioj/ABHexFile.html
The file also included for PlantPAx ModelBuilder
find out file "RSPPMB32.dll" at C:\Program Files\Rockwell Software\PlantPAx ModelBuilder\bin
change at the address FBCD9 : 34 02 to 30 90
and add .lic file at C:\Documents and Settings\All Users\Documents\Rockwell Automation\Activations
FEATURE PlantPAx_ModelBuilder.exe flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:PlantPAx_ModelBuilder.exe" SN=0000000001 \
SIGN="0034 5678 90AB CDEF 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
Before you change or overwrite the activation file, make sure all of the AB program are in shutoff (included RSLink and FTA).. or better you edited in Window "Safe Mode" by press F8 before running windows program.
Good Luck.![]()
Can you upload again in the rapidshare link?, i can not download from old link. thanks.luke12faulin wrote:Hi, Proeng
Good Luck.![]()
