[?]: How to install CVSS for dos plc program?
I have this program and I can not installed plese advised me
I am intall in dos mode
Установи CX-Programmer, он работает со всеми предыдущими типами файлов в том числе и с CVSS Ladder program (*.COD).
возможно понадобятся утилиты из комплекта CX-Programmer: SSS_File_Export and CXP_V1_File_Export
CX-Programmer File Conversion Utility
This is a generic file conversion utility that is able to convert files between the CX-Programmer project file format and files of other packages. It is a separate application from the main CX-Programmer interface.
Note: At the time of writing, converters are supplied to convert from files produced by the following OMRON packages: CVSS, CPT, LSS, SSS, SYSWIN. Currently, converters are not supplied for converting a CX-Programmer project for another package.
The file converter operates on (and produces) files of the .CXT format - the text-based format of a CX-Programmer project file.
Select the File Conversion Utility from the Windows Start / Programs / OMRON / CX-Programmer folder.
To convert another package's file to a CX-Programmer project, select Import from the File menu. A dialog opens allowing a different package's file to be selected. The File Type box at the bottom of the dialog allows a choice of file type. Select Open to start the conversion.
After the import conversion is complete, a .CXT file (with the same name) will have been created in the selected directory. The original file is left unaltered.
Note: The CXT file is a text-based CX-Programmer project file. To convert it to the compressed format, it may be loaded into CX-Programmer and then saved as a CXP type file.
To convert a CX-Programmer project for use in another application, first ensure that the project has been saved from CX-Programmer in the text based format (CXT). Then select Export from the File menu. A dialog opens allowing the source file name and type to be chosen. Select OK to start the conversion.
For export conversions, one or more files of the chosen type are created in the selected directory. The original .CXT file is left unaltered.
Some converters may have options, in which case they are accessible under the Options menu. Only converters with options are listed.
Hint: It is possible to list the converters that are installed, and their version, using the Help/About menu option. The converters are shown in the about box. To show details of a particular converter, select the relevant converter in the list and press Info.
CX-Programmer help.English wrote:Install CX -Programmer, it works with all previous types it is file including with CVSS Ladder program (*..CHOD).
utilities from complete set CX-Programmer, possibly will be required: SSS_.File_.Export and CXP_.V1_.File_.Export
you need create 2 disks and it works in cmd of XP
execut install of first disk and run CVSS.bat
link of program:
http://forums.mrplc.com/index.php?download=80
link of program:
Thank you for all to help
I still have problem because it doesn't work to install
I am dowload program and it have 3 folder that is CTOCV diskone disk two I run in command promt mode and try to install but I cannot install
after I enter to install diskone it show as below and can not to continue for
install(sorry I would like to attach picture but I can not)
C:\CVSS\CVSDI~2
most,I 'm not to see CVSS.bat for run
C:\CVSS\CVSDI~2
creates 2 disk's A:
execute cmd.exe
inserte the first and tip install
hit X = executes the installation
Y
Y
Insert disk 2 when ask ... and enter
rebbot
go to folder c:/CVS and hit CVSS.bat ....the program start
I do not have experience in this program ... I think that you goes to be a battle to communicate with plc
most
execute cmd.exe
Y
Y
rebbot
most
This link is "installed" program. just extract it in C:\ .
No need to install.
There is a "Shortcut to cvss.bat" run it.
http://plcforum.uz.ua//CVS.zip
No need to install.
