hi All,
I have successfully uploaded the program via CX Programmer v6.10. All blocks, including function blocks, were uploaded. However, when I compiled the program, I got syntax errors. The program is attached. Can somebody please solve this problem?
https://drive.google.com/drive/folders/ ... drive_link
Regards,
There seems to be an error while compiling the Omron PLC Programme
Re: There seems to be an error while compiling the Omron PLC Programme
Well, 85 errors, you have to try download again the complet program or have to correct this errors by hand. That's my opinion.
I tried 02 to 03 times but still got same error.can you please help me how to remove this errors means syntax etc.....
In windows, change the fractional part separator from "," to ".".
But this will not solve the problem in FB blocks.
One more thing can you please break the password of function block
