Diagnostics and Backup Omron PLC C200HS
CX-One, CX programmer, NTST, Syswin ....
JucaTec
Post by JucaTec » Mon Jul 19, 2021 1:59 pm
Hey.
I would like some help regarding an Omron C200HS PLC that is on old equipment, has been disassembled and assembled elsewhere but has been inactive for two years.
The authorized assistant reported that the PLC lost memory due to battery drain.
I'm new to PLC, I've already installed CX-One and I'm making the RS232 cable to communicate.
I would like to check if there is any way to see the errors that appear in the PLC and if possible make a memory backup.
So far I haven't tried to access the PLC through CX-Programmer and others.
I thank.
