I need an information (siemens is very complicated for me )
to use an TS Adapter 6ES7 972-0CA30-0XA0 in direct connection with S7-300 I need the program TeleService or this program is only for connect via modem
most
[?] TS Adapter
Re: [?] TS Adapter
You need install drivers from program TeleService.most wrote:I need an information (siemens is very complicated for me )
most
Key is not required for drivers.
You can also look at this.It's very usefull and it has the connection procedure.
Link_is_Dead :(/6ES7972-0CA23-0XA0.pdf
