Request: WinMod (grapichal simulation for S7)
I'm looking for Winmod : A program to simulate your s7 program in a graphical way.
http://www.winmod.de/www/eng/inc/was.html
Re: Request: WinMod (grapichal simulation for S7)
We continue waiting ...
i've got the installation files but no dongle (hardlock)
Does anyone have a dongle so we can make a dongle emulator for it ?
Has anybody managed to get it?
The Winmod Dongel is an "SG Lock" Dongel. For working with Winmod you need Programm,Dongel and licence file.
I think the best way is to patch the programm itself. "The drivers are inside the installation" so we have to patch every part.
Some drivers can not used because of an external Hardware. See here :
A710 for automation systems with PROFIBUS DP Monoslave-Emulation
A740 for automation systems with PROFIBUS DP Multislave-Emulation
A755 for SIMATIC S7/PCS7 Simulation for Remote Coupling with S7 PLCSim
A756 for SIMATIC S7/PCS7 Simulation for Remote Coupling with S7 PLCSim Advanced
A770 for SIMATIC S7 with MPI coupling (RS-232 and TCP/IP)
A780 for SIMATIC PCS7/S7 with PROFIBUS DP & PROFINET IO
B110 for EtherNET/IP coupling for Allen Bradley (Rockwell AS)
I200 for TCP/IP coupling for TwinCAT (Beckhoff)
I300 for TCP/IP coupling for B&R systems (control and fleet management systems)
X520 for INTERBUS Multislave-Emulation and PC WORX (PHOENIX CONTACT)
X620 for automation systems with MODBUS coupling (RS-232 or RS-485)
X620 I/O for automation systems with RS-232 or RS-485 for variable I/O coupling
X630 for automation systems with MODBUS coupling (TCP/IP)
X630 I/O for automation systems with TCP/IP (MODBUS) for variable I/O coupling
X640 Configuration Add-On for Configuration X630 for Modbus TCP Multislave Simulation
X700 for PROFINET IO Multidevice-Emulation and PC WORX (PHOENIX CONTACT)
Y200 with DLL Shared Memory for external applications
Y500 OPC - Client
Y500 OPC - Client
