[?]: profibus connector for CPU315-2DP and IM153-1
amet
Post by amet » Tue Sep 25, 2007 6:01 am
I use CPU315-2DP and IM153-1 with profibus.
I need 6GK1 500-0EA02 or 6ES7 972-0BB50-0XA0.
Wich use connector ?
gladiator
Re: [?]: profibus connector for CPU315-2DP and IM153-1
Post by gladiator » Thu Oct 04, 2007 11:32 pm
Use this one 90° cable outlet 6ES7 972-0BB50-0XA0 (with PG socket) or 6ES7972-0BA50-0XA0 (without PG socket) - Made in Czech.
Also these connectors 6ES7972-0BB41-0XA0 and 6ES7972-0BA41-0XA0 - Made in Gemany are the same.
The 180° cable outlet 6GK1 500-0EA02 is used for OP-TP only
amet wrote:I use CPU315-2DP and IM153-1 with profibus.
