[?]: Communicate s7-300 with s7-400 with profibus
alansal
Post by alansal » Mon Sep 24, 2007 1:09 pm
As the topic says... I need some description or/and some pdf's&documents about the subject....
Please also note that i am new to siemens(i have been dealing with Ge-Fanuc recently)...
Any information about siemens&ladder process (for dummies :P) would be very helpful indeed...
Thanks in advance....
Your earliest responses will be highly appreciated...
dante
Post by dante » Fri Oct 19, 2007 10:28 am
If you R so new (dummy) with Simatic, it is a good ideea to avoid for some while the communication over Profibus; any way U can use SFC's for PLC-PLC data transfer over Profibus.
Masta2002
Post by Masta2002 » Fri Oct 19, 2007 11:02 am
http://www.automation.siemens.com/fea/h ... module.htm
you can found some pdfs about profibus on this page not shure if this helps you
