[LINK]: dOPC www.dopc.kassl.de
Link
Post by Link » Sat Jan 13, 2007 8:52 am
http://rapidshare.com/files/11477514/dO ... ssl.de.rar 6 mb
Crack wrote:После инсталляции подмените *.dcu в каталоге установки
Replace these *.dcu files after installation
X:\Program Files\Kassl\dOPC\Lib7\.
http://www.dopc.kassl.de/
http://www.dopc.kassl.de/ wrote:OPC (formerly OLE for Process Control) is an industry standard created in collaboration
with a number of worldwide leading automation hardware and software manufacturers.
OPC allows software components such as software connectors to be combined and enables
these components to intercommunicate without special adaptions. Further information on
OPC can be found at: OPC Foundation and OPC Programmers' Connection.
Hence, Plug & Play has become reality in automation
Due to their variety of features and their simple handling, our products are successfully
being used already in more than 60 countries all over the world.
OPC Client Toolkits
dOPC Delphi Client Toolkit to develop OPC DA, XML DA and AE clients
dOPC C++ Builder Client Toolkit to develop OPC DA, XML DA and AE clients
dOPC Kylix Client Toolkit to develop OPC XML DA clients
OPC Utility Products
dOPC Clone to create OPC DA server simulators
dOPC Explorer is a program to read/write OPC Items from/to OPC COM or XML DA servers
OPC XML Server Gateways
dOPC XGate to enlarge any OPC COM based server with an OPC XML DA interface
dOPC XCOM gives any OPC COM based client access to OPC XML DA servers
androtx
Post by androtx » Tue Jan 16, 2007 5:41 pm
X:\Program Files\Kassl\dOPC\Lib7\ no found!!!! :( :( :(
Post by CoMod » Tue Jan 16, 2007 5:53 pm
Try find C:\Program Files\Kassl\dOPC\Lib7\
mmohamed15
Post by mmohamed15 » Fri Nov 30, 2007 9:24 pm
could you provide me with a crak for borland c++ builder
monty_burns_007
Post by monty_burns_007 » Fri Nov 30, 2007 11:33 pm
file posted here is OPC client for Delphi....
Could you post one for VB6 or (VB) .net as i don't use or have +Delphi or can we also use both files (.dcu) also for the other downloadable versions for VB, .Net or C Builder as a medizine ?
Or another Visual basic OPC activeX or client.
thanks a lot,
monty 8)
asm_Coder
Post by asm_Coder » Sat Dec 01, 2007 8:40 pm
hi monty_burns_007,
u can use SimaticNet for OPC client to Siemens products. Unimportant programming language for client.
bunglehead
Post by bunglehead » Sat Dec 01, 2007 8:52 pm
Simatic NET isn't a opc client
asm_Coder
Post by asm_Coder » Sun Dec 02, 2007 10:52 am
hi, bunglehead
I am using SimaticNet for connect to siemens plc and simotion with ethernet TCP/IP or DP. I can see server name is OPC.SimaticNET.
so may u tell me why isnt it opc client? What is different?
bunglehead
Post by bunglehead » Sun Dec 02, 2007 11:20 am
Simatic NET software provides necessary drivers for CPs and Siemens protocols and offer a OPC Server functionality. It includes OPC Scout (as opc browser and tool for testing OPC Servers). OPC Scout is opc client. OPC client is an another separate program often as a third party product. For Wonderware products it's OPC Link or more modern A2 compliant FSGateway. And this topic is about Delphi package for including opc client functionality into your applications.
mech962784
Post by mech962784 » Wed Jan 09, 2008 6:14 am
Please if anybody have the crack for the kassl opc gateway,
plese share it
best regards
codeX
Re: [LINK]: dOPC www.dopc.kassl.de
Post by codeX » Fri Aug 07, 2015 7:08 am
Hi dudes,
Can you share again the download link as Rapidshare link is not working any longer.
I would appreciate your support.
Please.
codeX.
djzurg
Post by djzurg » Mon Aug 20, 2018 5:39 pm
Hi!
Does anyone have Kassl dOPC ?..
dimodimo
Post by dimodimo » Wed Jan 02, 2019 1:18 pm
Hi!
Does anyone have Kassl dOPC v5?..
