http://plcforum.uz.ua/
[Request]: IBH Softec - S5/s7 Doctor - reverse engineering
http://plcforum.uz.ua/viewtopic.php?f=1&t=3293
Page 1 of 1
Author:  kazzuro [ Mon Jul 03, 2006 10:40 am ]
Post subject:  [Request]: IBH Softec - S5/s7 Doctor - reverse engineering
have you ever used S5/S7 Doctor from IBH Softec?
I had a demo version and I used it for S5 programmes. I think that it is great for reversed engineering. Unfortunatelly, it has only 14 days trial period and there is no way to connect to PLC online. So I am looking for S5/S7 Doctor in full version. Do yu know where can I find it?
Or maybe you know other similar programs?
Thanks in advance!
http://www.ibhsoftec-sps.de/english/first.htm
Author:  Link [ Tue Jul 04, 2006 2:00 am ]
Post subject:  Re: IBH Softec - S5/s7 Doctor - reverse engineering
Hello Kazzuro, am sending this link with the program, leaning that is this that you seek.
this works without code, I tested with CPU S7-314-2DP and he/she works in online.
happiness.
http://rapidshare.com/files/41511808/S7_Doctor_v2.23_with_crack.rar
include Ibh_Softec_s5W_v5-06_Full_Eng_.rar with crack
Author:  ppp [ Tue Aug 01, 2006 8:18 am ]
Post subject:  S7-Doctor v1.10 Full
http://rapidshare.com/files/141090350/S ... nglish.exe
http://narod.ru/disk/2303642000/S7-Doct ... h.exe.html
http://rapidshare.com/files/141090640/S ... ussian.exe
http://narod.ru/disk/2303650000/S7-Doct ... n.exe.html
http://rapidshare.com/files/141090817/S ... _v2.23.rar
http://narod.ru/disk/2303684000/S7_Doct ... 3.rar.html
Author:  sraiderk [ Thu Nov 23, 2006 11:03 pm ]
Post subject:
I installed S5/S7 Doctor v2.23 that was downloaded your link.
Afterthat I made everything in the readme file. But, program is still in demo mode.
Because I use the help->info about S5/S7 doctor toolbar, then It gives the demo information.
Is it in demo mode or not?
Author:  CoMod [ Thu Nov 23, 2006 11:46 pm ]
Post subject:
from README
Only english version is cracked!
During installation choose english language.
Install "S7-Doctor" as "DEMO".
After installation copy "Run S7-Doctor.exe" to program folder.
For using S7-Doctor without any limitations start "Run S7-Doctor.exe".
I try. Only diference - no registration window when Start.
Единственное отличие - нет окна регистрации при запуске.
But / Ho
Инсталлируйте "S7-Doctor" как "ДЕМО". После инсталляции скопируйте файл "Run S7-Doctor.exe" в каталог установки. Для использования S7-Doctor без всяких ограничений запускайте "Run S7-Doctor.exe".
Крякнута только английская версия! При инсталляции выберите английский язык.
Author:  henk [ Fri Nov 24, 2006 1:17 am ]
Post subject:
IT WORKS!!!!!! :D :D :D
Henk
Author:  sraiderk [ Mon Nov 27, 2006 8:34 pm ]
Post subject:
CoMod,
I apoligize from you. You are right. It works on my other pc. But, this pc still has problem. Of course this is my problem. Thanks...
Author:  KoliaMor [ Thu Nov 08, 2007 4:01 pm ]
Post subject:
I need help!!!!!
S5 S7 Docrot under runing generated ERROR:
<Instruction at adress 0x00404a79 call to memory at adres 0x00000018
Memory cannot written>
OS - Widows XP SP2 with Microsoft. NET Framework 1.1
:?: :?: What is problem. :?: :?:
Author:  Link [ Fri Aug 29, 2008 7:44 pm ]
Post subject:
Scowl wrote:
I cann't download these files
Author:  Link [ Mon Mar 02, 2009 5:02 am ]
Post subject:  S5 S7 Docrot V2.25
S5 S7 Docrot V2.25
English // German
[dead]
rapidshare S7_Doctor_225.zip
Author:  venix [ Wed Mar 04, 2009 11:28 pm ]
Post subject:
Does anybody succeded to connect online with this software?
I tried and with no succes.I am using a USB-Serial adapter.
With S5/S7 for Windows I had no problem,also with PG2000.
Best regards,
Venix
Author:  dekor [ Thu Mar 05, 2009 10:32 am ]
Post subject:  Try to use this converter
I use for connection a USB-RS232 adapter. I use this soft also with this adapter.
Check on manufacturer web site.
Check on this link : http://apple.clickandbuild.com/cnb/shop ... tle=UC232R
The manufacturer has a local distributor also in your country.
dekor
Author:  kiran kalburgi [ Sat Jan 16, 2010 2:04 pm ]
Post subject:  Re: [LINK]: IBH Softec - S5/s7 Doctor - reverse engineering
kazzuro wrote:
Thanks in advance!
http://www.ibhsoftec-sps.de/german/Doctor_1.htm
http://www.ibhsoftec-sps.de/english/Doctor_1.htm
Hello can u tell me how can i add a new GSD file to this S5/S7 Doctor :cry:
Author:  rajume06 [ Mon Oct 27, 2014 1:07 am ]
Dear Link,
All rapidshare link are dead. and i can't download from narod.ru, because i don't know download procedure from this site. Please tell me how can i do this? or another link.
Thanks in Advance
Author:  eng_no1 [ Fri Mar 03, 2017 5:40 pm ]
links not work please update
Author:  simatic1971 [ Sun Apr 16, 2017 12:23 pm ]
Post subject:  Re: [Request]: IBH Softec - S5/s7 Doctor - reverse engineeri
If someone can serve here is the active link (suc)
http://www.easybytez.com/uofkmru5y1tq
Author:  autosystem [ Tue Jan 09, 2018 8:36 pm ]
download link is corrupt, please upload file again. thanks
Author:  Nedjeljko [ Wed Mar 14, 2018 12:59 pm ]
Can someoen reupload somwhere this tool?
Thank you in advance.
Author:  ATech [ Thu Apr 05, 2018 4:34 pm ]
Please update the download link. Thank you!
Author:  winice [ Fri May 11, 2018 11:36 am ]
https://rutracker.org/forum/viewtopic.php?t=2797223
Author:  simatic1971 [ Tue Jul 17, 2018 3:16 pm ]
http://www.easybytez.com/2xgtj2a55m6a
http://www.phpbb.com/
