[?]: Project PCS7 Alarms in TIA portal
Facu2998
Post by Facu2998 » Thu Sep 14, 2023 11:40 am
I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system.
This necessitates the use of TIA Portal (v17) to seamlessly integrate PCS7 with the Operator Panel.
To import alarms into the TIA Portal via device proxy, I've been following the guidelines outlined in the document "50708061_application_pcs7_panel_integration_en".
The import process appears to have been successful.
Additionally, I've integrated the panel blocks from the Industry Library in TIA.
However, I've encountered an issue where alarms, when triggered, do not seem to appear on either the faceplate or the alarm display on the Panel.
Any insights on resolving this would be greatly appreciated.
Also I connect the Panel Blocks to the blocks in TIA Portal Correctly ¿Is there something that I need to do to get it right?
Greetings.
