PLC Analyser V5.4 Problem on VM
Salpicona
Post by Salpicona » Mon Jun 29, 2020 3:02 pm
Hi all,
I have PLC Analyser installed in Oracle VM, win7.
When i run the VM with higher than 4Gb Ram the application does not start. (the anawin.exe process starts but ends without exit status 0x0 on event viewer).
Although, if i use less or equal to 4Gb ram, the application starts ok.
As anyone faced the same issue?
smallandquiet
Re: PLC Analyser V5.4 Problem on VM
Post by smallandquiet » Thu Sep 17, 2020 11:01 am
Yes. Because the software with this version only can support OS bit 32 like WinXP X86. RAM above 4G is for X64 normally.
wuliang55
Post by wuliang55 » Thu Sep 17, 2020 11:22 am
Yes. Because the software with this version only can support OS 32 Bit like WinXP X86. RAM above 4G is for X64 normally.
ermohamed07
Post by ermohamed07 » Mon Jul 24, 2023 12:11 pm
PLC Analyser driver not loaded error
