It is currently Mon Dec 10, 2018 2:09 pm
PostPosted: Fri Oct 26, 2018 5:07 pm
Hello yall,
First of all Im kinda noob to communications with Siemens PLCs...
Im trying to simulate communications between 2 cpus (s7-300 for example) and I was told that it is possible using PLCSim 5.4 Sp3 HF1...
But every test I did whent bust... Using CPs, using CPs integrated with the CPUs... Every try I did went wrong one way or another... (h)
Does anyone have a simple program with hw configured and can send me pls pls pls...
Or maybe a doc where it explains how to configure a 2 cpu communication using profibus/profinet that can be simulated using plcsim?
PostPosted: Fri Oct 26, 2018 8:03 pm
(sfaq) https://support.industry.siemens.com/cs/document/38726591/how-do-you-simulate-communication-between-two-cpu-modules
https://support.industry.siemens.com/cs/document/88781327/how-do-you-simulate-s7-communication-between-two-s7-1500-cpus-using-s7-plcsim-v13
