It is currently Sat Jul 21, 2018 9:11 am
 Post subject: Step 7 V 5.5 Copy DB
PostPosted: Mon May 14, 2018 6:13 pm
Здравствуйте!
Подскажите как в Степ 7 в ДБшке затянуть Актуальные значения (Actual Value) в Инициализационные (Initial Value)?
Заранее спасибо.
 Post subject: Re: Step 7 V 5.5 Copy DB
PostPosted: Sat May 19, 2018 8:34 pm
Open DB file => Go to View => Switch from Data View to Declaration View => Place your data in Initial Value field => Save.
All DB editing goes in "Declaration View"
PostPosted: Sun May 20, 2018 11:28 pm
Спасибо за ответ.
Таким образом можно изменять только по одному значению
Хотелось бы скопировать и вставить сразу все значения из DB.
PostPosted: Wed May 23, 2018 11:29 pm
By hand only :(
Lots of time DB is type of UDT. It means you will need to edit UDT, which is not a good approach.
PostPosted: Tue Jun 05, 2018 4:20 pm
Hello!
More easy is to create a Source form the DB and to edit/,modify as you wish in the source code stl.
Best regards!
PostPosted: Fri Jun 15, 2018 5:32 pm
What is easier? Also need handles to work.
