Configuration Netpro
rayen_6827
Post by rayen_6827 » Fri Mar 09, 2018 3:45 pm
I have questions about network architecture and configuration in Netpro.
I send you a picture of the entire configuratin of Netpro and pdf configuration plc's and Please you answer my questions.
1-Should be Terminal Bus configured in Net Pro?(Is it necessary to configure the TerminalBus separately in Net Pro?)
2-What is your opinion about configuration the network bus network in Netpro?Is there a redundancy?(Do two network PlantBus to be configured in Net Pro or not ?)
link files of configuration: http://s000.tinyupload.com/download.php ... 1786131794
http://s000.tinyupload.com/download.php ... 4618789416
in the page61 and 63 manual https://cache.industry.siemens.com/dl/f ... _en-US.pdf *SIMATIC
Process Control System PCS 7
Fault-tolerant Process Control
Systems
* of siemens there are 2 Solutions for the plant bus
The system is redundant, fault-tolerant plant bus or not?
Why in our system for each server, there are two 1623 cards installed, but next to each CPU is one card 443-1
Is this correct?
