The calculation results show "NaN",pls help me
auto_man
Post by auto_man » Wed Aug 09, 2017 2:07 am
I have a project used PCS7V8.2 & IL & 315-2DP,
and I create a FB like "Lag" in APL.
The SCL program is shown as follows:
OUT := SEL(G:=LAG_T<=0.0,IN0:=IN + (sr_lv_out-IN)*(EXP(-Sample_T/LAG_T)),IN1:=IN);
sr_lv_out := OUT;
If the input ("IN") is fixed in a negative number always , and a few hours later,the output("OUT") shows “NaN”.
Why?
Is floating-point calculation overflow ?
qqwww
Re: The calculation results show "NaN",pls help me
Post by qqwww » Wed Aug 09, 2017 5:59 pm
Show whole FB (with interface)
Enrico999
Post by Enrico999 » Thu Aug 10, 2017 7:05 pm
"NaN" means "Not a Number".
To find the error we need to see the whole block !
AlekMalek
Post by AlekMalek » Mon Dec 18, 2017 7:43 am
Check your formula. It seems that the output of your function divides on 0 or the output is infinit or out of range of your variable.
