Hello everyone,
I have just started learning about PLCs as a hobby. I have prepared following setup,
Main Controller
Controller: S7-1200
Inputs: Push Buttons (x2) (turns a lamp connected at ET station on and off)
Output: None
ET Station
ET: ET200S
IM: IM 151-3
Inputs: None
Outputs: Lamp
Main controller and ET stations are connected through PROFINET. When the buttons are pressed at Main Controller, the lamps at ET stations are turned on or off.
Question: I was thinking that if I were to add more ET stations in a daisy chain manner, is there a possibility to make just one function to turn on/off the lamp and based on the parameter passed to the function, it decided with I/O tag to refer to.
I apologise if the question is not clear, please let me know if so and I will try to explain it in a better way.
Thanks!
[?]: Functions to repeat instructions for ET stations
Re: [?]: Functions to repeat instructions for ET stations
---|Button|-------------(Lamp)
Use indirect adressing, for S7-1200, take a look at peek and poke instruction.
Best regard.
Best regard.
