It is currently Wed May 23, 2018 11:48 pm
Post new topic Reply to topic  [ 49 posts ]
PostPosted: Sat Apr 09, 2016 9:24 am
Hello everyone.
Can some one point mi to the installation media of CPU 1507s?
i'd like to test it.
PostPosted: Thu Apr 14, 2016 2:47 pm
The product code is SIMATIC SOFTWARE CONTROLLER CPU 1507S DL (6ES7672-7AC00-0YG0)
If anyone has it, please upload it! (tyou)
 Post subject: CPU 1507s =1505S
PostPosted: Thu Apr 14, 2016 11:29 pm
about https://support.industry.siemens.com/cs/document/109478535/current-version-s7-1500-software-controller-v1-8-for-et-200sp-open-controller
link https://support.industry.siemens.com/cs/document/109478528/current-revision-levels-of-simatic-s7-1500-software-controller-?dti=0&dl=en
CPU 1505S - PREINSTALLED ON ET 200SP OPEN CONTROLLER
6ES7672-5AC00-0YA0
SIMATIC S7-1500 SOFTWARE CTRL CPU 1505S
SIMATIC S7-1500 SOFTWARE CONTROLLER CPU 1505S VERSION 1, SINGLE LICENSE F. 1 INSTALL, R-SW, CLASS A, 6 LANGUAGES: GE,EN,IT,FR,SP,CH;
1507S ON DVD SIMATIC_CPU1505S_V1.8.1.iso (589,2 MB)
6ES7672-7AC00-0YA0
SIMATIC S7-1500, SOFTWARE CONTROLLER CPU 1507S VERSION 1.8, SINGLE LICENSE F. 1 INSTALL, R-SW, SW AND DOCU.
ON DVD, LICENSE KEY ON USB STICK, RT-SW CLASS A, 6 LANGUAGES (GE,EN,FR,IT,SP,CN) EXECUTABLE UNDER WINDOWS 7 REFERENCE-HW: SIMATIC IPC4X7D, IPC6X7D, IPC8X7D
For install on PC it required 2 partions on disk
https://support.industry.siemens.com/cs/document/104943430/simatic-s7-1500-software-controller-additional-information-on-cpu-1505s-cpu-1507s
SIMATIC S7-1500 Software Controller Additional Information on CPU 1505S/CPU 1507S
Creation of the CPU volume
Introduction
The CPU makes use of the mass storage of the PC on which it is installed. During the installation, a discrete CPU volume is
created in the mass storage, in which all CPU data is stored. The load and retentive memories are integrated into this CPU
volume.
Note
Size of the CPU volume
In order to ensure reliable operation of the CPU, the CPU volume must not be reduced during operation. If you reduce the
assigned mass storage area, this can lead to data loss or even a CPU crash.
 Post subject: Re: [REQUEST] CPU 1507s
PostPosted: Sun May 01, 2016 4:12 pm
is it possible to intall SIMATIC_CPU1505S_V1.8.1.iso (589,2 MB) on a normal PC?
IF YES,HOW?
PostPosted: Wed May 04, 2016 9:13 am
After installing the SIMATIC_CPU1505S_V1.8.1 on normal pc,I got a error screen saying fatal error unsupported pc type,how to solve this problem.
PostPosted: Fri May 06, 2016 9:37 am
Yes, correct. thats what happen with 1505S. I was successful removing that alarm modifying the bios in a virtual machine but after that i got another cpu error message.
Thats why i was looking for the 1507S iso.
PostPosted: Fri May 06, 2016 12:18 pm
If you get it,and eventually make it run on normal pc,don't keep it.
PostPosted: Sat Aug 20, 2016 6:01 pm
can u share the method how to modify ths bios in the virtual machine ?
PostPosted: Mon Aug 29, 2016 11:15 pm
I uploaded 1507S here: viewtopic.php?f=30&t=24416
Please share your method for modifying the virtual machine bios
PostPosted: Fri Sep 23, 2016 9:50 am
I'm also searching for a method to run the controller on vmware.
PostPosted: Sun Oct 02, 2016 3:27 pm
if we want to modify the bios of the vm,
we need the bios information of a running IPC which 1507 runs on,
use the tool
http://gnuwin32.sourceforge.net/packages/dmidecode.htm
to dump the bios,
then ........
can u have a simens IPC which runs 1507 software CPU?
if u have, can u use hexedit to dump the CPU volume to a file?
PostPosted: Mon Oct 03, 2016 1:29 pm
Sorry, I don't have access to a compatible Siemens IPC...
PostPosted: Mon Oct 03, 2016 8:06 pm
(sdoc) Delivery Release for SIMATIC S7-1500 Software Controller V2.0
https://support.industry.siemens.com/cs/document/109740652/delivery-release-for-simatic-s7-1500-software-controller-v2-0?dti=0&dl=en
PostPosted: Tue Oct 04, 2016 4:00 am
Microbox PC IPC427D
Box PCs IPC227E, IPC627D and IPC827D,
Panel PCs IPC277E,IPC477D and IPC677D
Rack PCs IPC647D and IPC847D
the cheapest one may be IPC227E.
at this URL,
https://support.industry.siemens.com/cs/document/109481715/simatic-ipc227e-(nanobox-pc)-latest-bios-version?dti=0&lc=en-DE
we can download the Latest BIOS file,
can u upload the file?
PostPosted: Tue Oct 04, 2016 4:34 pm
The smallest one supported seems to be the SIMATIC IPC427D.
I have uploaded the latest bios for it here:
https://mega.nz/#!0ZcHkA4D!0w_bt6BTw0XM ... DP17Ssvvk4
PostPosted: Tue Oct 04, 2016 5:14 pm
thanks a lot!
another error occurs.
i thanks it must be about the CPU volume.
PostPosted: Tue Oct 04, 2016 5:45 pm
Can you tell me what you have modified in the vmware bios. I want to experiment a bit myself.
PostPosted: Tue Oct 04, 2016 8:02 pm
I am using VMware so I had to change the DMI strings in the BIOS file.
Before I got the same "Unsupported PC type" now I get a different error:
PostPosted: Wed Oct 05, 2016 11:27 am
how many cores do you set in the vm?
when i try to set 2 cores in the vm,
i get the error as you post,
after i change it back to 1 core,
my error occurs again.
PostPosted: Wed Oct 05, 2016 11:57 am
I only tried 2 and 4 cores.
You need at least 2...
1 core for the cpu, the rest for windows
PostPosted: Wed Oct 05, 2016 5:16 pm
What does "module +16" mean in Grub4Dos?
What is "{FBBDD621-CB50-491C-986F-F05B42E80B95}"?
Anyone can help ?
PostPosted: Thu Oct 06, 2016 10:20 am
Description is here
13.3.25 module
— Command: module file ...
Load a boot module file for a Multiboot format boot image (no interpretation of the file contents are made, so the user of this command must know what the kernel in question expects). The rest of the line is passed as the module command-line, like the kernel command. You must load a Multiboot kernel image before loading any module. See also modulenounzip.
PostPosted: Fri Oct 07, 2016 5:06 am
that is right,but i already know about it, the manual does NOT talk about "module +16".
PostPosted: Fri Oct 07, 2016 9:15 am
After modify some parts of the kernel,
I can this error
Left image is the real PC,right image is the virtualbox,
The real PC supports VT-X,but the virtualbox does NOT.
As we can NOT run a virtualbox in a virtualbox,
We can not test 1507 on a virtualbox either.
We must use a real PC.
PostPosted: Fri Oct 07, 2016 12:39 pm
yanzixiang wrote:
After modify some parts of the kernel....
Which modifications on the kernel have you done? Can you provide some detailed information/files?
I'm playing arround with Vmware and I saw that I have VT-x support inside the virtual machine.
But my problem is, that I have an hardware error on core 0 at startup.
The error with the manufacturer is already fixed.
PostPosted: Mon Oct 24, 2016 6:09 pm
Got any progress using a vmware image?
Did you get a working bios? can you share some details
John
PostPosted: Thu Oct 27, 2016 2:42 pm
some guys asked me what modifications have I did.
I disassembed the kernel,
and guese where to modify,
up to this time,
I failed.
There are so many tests,
and i have no clue.
If we can have one running BOX in touch for test,
maybe we can make it.
I upload the modified kernel files,
if u guys want to test it ,
please backup your vmm.elf and replace it with my vmm.elf.
If u have good luck,
let me know.
[url]链接: https://pan.baidu.com/s/1o8NcVLw 密码: err6[/url]
PostPosted: Wed Nov 02, 2016 4:54 pm
Hello.
I tried your elf but got no result (fatal error or crash)
I guess you used a custom bios for the virtual machine (otherwise you might get "unsupported pc type").
I used a tweaked version of FUJITSU211_314.ROM (the Bios file I used for WinAC RTX under vmware) and replaced the "vmware" vendor strings with "siemens". With that I got past the "unsupported pc type" but got other faults.
What "bios" file did you use?(under entry "bios440.filename=" inside the vmware .vmx file)
In one of your screenshot i saw an error "vmx disabled"..... that error theoretically can be avoided setting the setting "Virtualize intel VT-x/EPT" setting... did you try that?
bye
john
PostPosted: Sat Nov 05, 2016 1:02 pm
I used a REAL pc box.
I have knows about the setting "Virtualize intel VT-x/EPT" already,
PostPosted: Mon Nov 21, 2016 7:21 pm
Must try with v2.0 ISO. On OpenController eveything works fine.
PostPosted: Fri Nov 25, 2016 10:51 pm
Can someone post the 2.0Iso and a workaround to run it on vmwaRE?
PostPosted: Sun Jan 01, 2017 8:05 pm
could somebody point me to the download of the CPU1507S V2.0, i search already days bu didnt found. I like ti install this and test it. Same like with the Runtime of WinCC V14.
Thanks a lot.
PostPosted: Tue Mar 28, 2017 11:09 am
I'm also searching for the latest CPU1507S V2.0 ISO image. Is nobody here that can provide the iso?
PostPosted: Mon Apr 10, 2017 7:46 pm
https://support.industry.siemens.com/cs ... 0&lc=de-DE
Only DE Site !
PostPosted: Sat Apr 22, 2017 5:12 pm
Actually it´s not possible to get it running on "normal" PC.
Tested with V2.0 ISO on "normal" PC (not dedicated SIMATIC BOX PC)
PostPosted: Tue Jul 04, 2017 10:06 am
i guess, there are not other news to run this on a non-simatic pc?
PostPosted: Mon Oct 02, 2017 3:54 am
https://support.industry.siemens.com/cs/attachments/109478528/SIMATIC_CPU_1507S_V2_1.exe
https://support.industry.siemens.com/cs/document/109478528/aktuelle-korrekturst%C3%A4nde-simatic-s7-1500-software-controller
There is a new version of V2.1, the friend can help download, I can not register Siemens Global Center account, I will express my thanks!
PostPosted: Mon Oct 02, 2017 9:45 am
hanjinxing wrote:
https://mega.nz/#F!NH4gmTrK!bsQdNaTwp2gAN0sdSeyWPw
PostPosted: Fri Oct 06, 2017 5:39 am
There is a new version of V2.1, the friend can help download, I can not register Siemens Global Center account, I will express my thanks![/quote]
https://mega.nz/#F!NH4gmTrK!bsQdNaTwp2gAN0sdSeyWPw[/quote]
The link I can not open, can help provide other download links? Express thankfulness!
PostPosted: Tue Oct 10, 2017 8:44 am
hanjinxing wrote:
The link I can not open, can help provide other download links? Express thankfulness! (dlink)
install mega plugin to Firefox
PostPosted: Thu Oct 26, 2017 11:59 am
Thank you everyone! China is a large local area network, individual rights have been deprived (no)
PostPosted: Thu Oct 26, 2017 12:22 pm
Yandex disk ?
https://yadi.sk/d/03a7OOLK3P7M73
PostPosted: Fri Oct 27, 2017 6:32 am
Link wrote:
Yandex disk ?
Thank you very much! The The
PostPosted: Wed Nov 29, 2017 4:57 am
PostPosted: Mon Dec 04, 2017 7:07 am
It seems that v2.1 need a new authorization,the latest Sim_EKB_Install have not had it yet?
PostPosted: Mon Dec 04, 2017 9:27 am
https://mega.nz/#F!DsNy1DqR!p751JvORlgTeWsGSiTuWLQ
PostPosted: Tue Dec 05, 2017 5:58 am
After installing the new license, the same problem
PostPosted: Tue Dec 05, 2017 8:48 am
Ctrl+Alt+Del is not problem of new key :)
PostPosted: Tue May 22, 2018 4:11 pm
Is this thread dead? No more trying to make it work under VM or regular PC?
Amarillo
Users browsing this forum: No registered users and 12 guests
