Panel OP7 not communicating V3.01 / 04 CPU 313-2 DP V1.0 Sie
Panel OP7 V3.01/04 not communicating with CPU 313-2
Re: Panel OP7 not communicating V3.01 / 04 CPU 313-2 DP V1.0
The panels OP7 were for the old version SIMATIK 5.
Вполне возможно это панель для S5.
CPU 313-2 DP ? or CPU 313C-2 DP ?Panel OP7 V3.01/04 not communicating with CPU 313-2 DP
OP7 PP for S5 6AV3607-1JC00-0AX1 https://support.industry.siemens.com/cs ... 1JC00-0AX1
OP7/DP for S7 1.5 MBAUD 6AV3607-1JC20-0AX1 https://support.industry.siemens.com/cs ... 1JC20-0AX1
Use ProoTool ? Windows XP ?
