S7-315 2PN/DP with CP343-1 Lean as Modbus TCP/IP Master?!
alansal
Post by alansal » Thu Jul 09, 2015 2:08 pm
Hello everyone,
I need to read a couple of holding registers (from 700 to 750) and write some (800 to 850) using MB over TCP/IP. This also has to be done as a master.
As always many many thanks in advance...
Kind Regards,
(tyou)
alansal
Re: S7-315 2PN/DP with CP343-1 Lean as Modbus TCP/IP Master?
Post by alansal » Tue Jul 14, 2015 2:16 pm
Can at least someone help for Modbus Master?!
Besides is there anyone that can tell me how many modbus communications can a 315-2PN/DP have?
Thanks in advance....
Umencho
Post by Umencho » Wed Jul 15, 2015 5:48 am
https://support.industry.siemens.com/cs ... nglish.pdf
The maximum number of Modbus clients that can be connected to port 502
of the CPU is CPU-specific and can be found in the technical data of the
CPU.
