Motor FDB compile Help
a_rishi
Post by a_rishi » Thu Mar 12, 2015 7:41 pm
Hi Everybody
I'm new to Siemens PLC and is working on a Poject for m course.
I'm trying to build a DFB Motor for Global use.
I have the code in SCL but there are certain errors such as the Bit Second (1 Sec), the Rising edge of the Bit Second, etc.
Please clarify how can we insert Bit Second in SCL and its Rising edge.
Kindly check the FDB structure Text and help me to clear the faults. I could not attached the FDB due to size limit. Please Download it from
https://www.dropbox.com/s/aeuuz3w3bk...Motor.zip?dl=0
Kind Regards
Answers to FAQs
Faq & Info
Faq & Info
Re: Motor FDB compile Help
Post by Answers to FAQs » Fri Mar 13, 2015 5:34 am
a_rishi
FB Programming in SCL for S7-400
Post by a_rishi » Fri Mar 13, 2015 5:38 am
Hi Everybody
How can we program a Timer, Bit Seconds and Rising Edge of Bit Second using SCL for a FB in TIA Portal for S7-400. Can you please elaborate the code for these functions. I also want to compare the Timer Output with a set point (word) and set an output if the Timer output is less or greater than the set point.
Answers to FAQs
Faq & Info
Faq & Info
Post by Answers to FAQs » Fri Mar 13, 2015 5:47 am
open manual of scl & read
a_rishi
Post by a_rishi » Fri Mar 13, 2015 5:54 am
I'm completely new to SCL & Siemens. The manuals are not explicit enough an could not get a proper solution.
Any help would be most welcome
