[?]: TIA portal v13 and s7-1200 with TIA 11/12
sandumon84
Post by sandumon84 » Wed Jan 21, 2015 9:09 am
sandumon84 wrote:Hi expertz,
I have two query
A>I am a fresher to siemens step7 .
I have installed TIA portal v13 in my laptop .
We have a customer who is having Simatic s7 1200 controller so I need to upload the program from the device.
The problem is customer have no idea who downloaded or which version of step 7 used for programming the device.
My question is if i upload the program with TIA portal v13 any errors will come up or how can i upload the program.
B> Whenver I am opening the TIA portal v13 ( installed in Windows 8 ) I am getting one error message " following assemblies not found .....
Hi experts
I am new to siemens so looking for advice on the following issues
I have a plc -S7 1200 which is running at site
we dont have any backup or software for the same so I downloaded TIA portal v13 from siemens site then I connected the PLC and I was able to go online but while uploading the program I got an error message " preconditions are not met" so I checked the diagnostics and it was displaying version missmatch ( configuation in control is tia portal v11 ) so I tried to get a tia portal v11 trial from internet but no success is there any way to sort out this
It would b helpful if any can send the link for tia portal v11
Sandy
Homeroid_BL
Re: [?]: TIA portal v13 and s7-1200 with TIA 11/12
Post by Homeroid_BL » Wed Jan 21, 2015 7:10 pm
Here on Plcforim there is TIAP V11 + SP2, just search for it.
misa1515
Post by misa1515 » Fri Jan 23, 2015 6:03 am
maybe this will help to you
(FAQ: In STEP 7 (TIA Portal) V13 SP1, how do you load project data from a device that has been configured with STEP 7 (TIA Portal) V12 or V13?)
https://support.automation.siemens.com/ ... d=82169157
sandumon84
Post by sandumon84 » Sun Jan 25, 2015 9:49 am
Thanks for the info
I have installed TIA portal v12 SP1 so when I tried to upload from the controller (S71200) I got error " Project inside controller is v11 and incompatible etc) So I downloaded the compatibility mode project from siemens support site and uploaded successfully now my doubt is whether I can easily download with my current software TIA Portal v12sp1 without any error or I should get V11..
thankz
sandumon84
Post by sandumon84 » Wed Jan 28, 2015 8:51 am
Can any body share TIA Portal V11 link
I searchd a lot but no success
DiVan
Post by DiVan » Wed Jan 28, 2015 9:10 am
sandumon84
Post by sandumon84 » Sat Jan 31, 2015 6:53 am
Hi
I tried to download the torrent but after registering no response
