Sinumerik 840D cycle writes a PLC bit and reads it.
AirMach
Post by AirMach »
Hi all,
I need to execute a customized cycle, at the begining it's supposed to write a bit in the PLC memory and after doing the regular cycle, it has to read the bit and send it back to the HMI.
I've been reading a lot of info but I cant find the way to access to a PLC bit without using the HMI, How would the header be to activate a bit in a DB?
Any answer will be appreciated,
Cheers!
ikavakci
Re: Sinumerik 840D cycle writes a PLC bit and reads it.
Post by ikavakci »
There are 3 way.
1- You can write m code.
sample...nc program M25...plc db21.dbx197.1
2-you can use ncvar program for creating source code, read and write plc
3- you can use vb6 and read-write plc-nc-mmc parameters,memory,datablocks etc.
if you explain yor problem?
I can help you
ikavakci@cozumotomasyon.com
