how to assign array[x] ? in Step 7 5.5
relay
Post by relay » Thu Dec 06, 2012 11:55 am
Hi all! it's possible to assign the single array position using in stand of array[1] the array[x]?
ex:
var1 array [0..15] of bool
SET
S var1[x] (in stand of var1[1]
what kind of variable should be "x"?
I tried but it seems no one kind of variable is accepted
relay
Re: how to assign array[x] ? in Step 7 5.5
Post by relay » Thu Dec 06, 2012 6:53 pm
I take a look for..no way, just with SCL is possible var1 where i=INT
Lepes9
Post by Lepes9 » Thu Dec 06, 2012 11:25 pm
Hi relay,
It is possible. Try something like this:
      L W#16#0
      T LW 0
      LAR1  P##VAR1
      L     #VAR_X
      +AR1
      SET
      =     L [AR1,P#0.0]
where VAR1 is an Array [0..15] Of Bool in the TEMP data section at Address 0.0 (I used an FC to test it).
It's just a short example written in a minute. Do you need more information?
Greet
Lepes9
relay
Post by relay » Fri Dec 07, 2012 9:33 am
Tnx lepes9!
