[?+]: cant see the comment for db68
niila
Post by niila » Tue May 24, 2011 1:27 pm
hi
i created data block on s7 300 project then i wrote my comment but related function fc dont indicate it
for ex: in data block db68.dbx14.1 'filtration' isnt indicated on function it still keep to show 'db68.dbx14.1' eventhough saved
thanx in advance
dsekulic
Re: cant see the comment
Post by dsekulic » Tue May 24, 2011 2:23 pm
First You have to check if You give symbolic name to data block (DB68). You should do this in Simatic Manager (right click on DB68 -> Object Properties and put Symbolic Name). Then in LAD/STL/FBD editor You should check View -> Display with -> Symbolic representation. Now You should be able to see symbolic name of Your variable.
niila
Re: [?]: cant see the comment for db68
Post by niila » Tue May 24, 2011 2:56 pm
Hi dsekulic
first thanx for your quick reply
it s ok now :D
