It is currently Wed Feb 21, 2018 12:37 pm
Post new topic Reply to topic  [ 28 posts ]
PostPosted: Fri Aug 27, 2010 10:25 am
In new version 5.5 not visible password under stars .
PostPosted: Fri Aug 27, 2010 11:17 am
There is a new feature in Step7 v. 5.5 called S7 Block Privacy (installation is available at CD_2\Optional Components\S7 Block Privacy).
As I understand, it is an alternative to obsolete "Know-How protection". The question is if it's possible to open blocks that are protected with S7 Block Privacy without knowledge of a password. :?:
PostPosted: Fri Aug 27, 2010 10:35 pm
Step7 V5.5 new S7-Block Privacy
http://www.youtube.com/watch?v=XW5hcWRdB7Q
The program-code will be encrypted with 128 Bit on the PG, encoded transmitted and decrypted on the controller.
BlockPrivacy_README wrote:
SIMATIC S7 Block Privacy V1.0
2.1 General Notes
· The call for the S7 Block Privacy application is integrated in the SIMATIC Manager. It is always called in the shortcut menu of the block folder (menu command "Block Privacy..."), this means that the STEP 7 project and the S7 program are specified for the called S7 Block Privacy instance. If an S7 Block Privacy instance exists when you call S7 Block Privacy for a different S7 program, the new parameters (STEP 7 project and S7 program) are passed to the running program.
· S7 Block Privacy supports function blocks(FB) and functions (FC).
· The CPU must have at least the following version:
o CPU 3xx: firmware version V3.2 or higher
o CPU 4xx: firmware version V6.0 or higher
· Following encryption, the encrypted blocks are available in the databases of a STEP 7 project.
· Encrypted blocks cannot be processed with earlier versions STEP 7 (call, instantiation etc.).
· The S7 Block Privacy application works only in conjunction with the SIMATIC Manager. Exiting the SIMATIC Manager also exits S7 Block Privacy.
· Encrypted blocks cannot be simulated with S7-PLCSIM.
Russian wrote:
Новый метод защиты функциональных блоков (FB) и функций (FC) в Step7 V5.5.
Программный код шифруется 128 битным ключом в программаторе, в защифрованном виде передаётся в контроллер, где и дешифруется.
Данный метод защиты блоков применим только к новым процессорам s7-300 V3.2 и s7-400 V6.0.
Защищённые данным методом блоки нельзя открыть в предыдущих версиях Степ7.
Защищённые данным методом блоки нельзя симулировать в S7-PLCSIM.
PostPosted: Wed Sep 01, 2010 6:56 pm
and WinAcRTX...?
..................... (tyou)
PostPosted: Thu Sep 02, 2010 11:18 pm
ilndep wrote:
I install Step7 V5.5 and after new S7-Block Privacy but when I lunch S7-Block Privacy the same program close immediatly. Why ?
The installation of Step 7 V5.5 overwrite Step7 V5.4
In my comp is Ok.
PostPosted: Fri Sep 03, 2010 7:50 pm
Hi CoMod,
to run S7-Block Privacy I must close all files of antivirus by Task Manager Windows.
What is the connection with antivirus ?
PostPosted: Fri Sep 03, 2010 8:03 pm
Where is connection with antivirus ?
With KIS2011 it work.
See blocked program and unblock S7-Block Privacy :)
PostPosted: Fri Sep 03, 2010 9:32 pm
The program is not blocked but it is closed in automatic !!!
I don't understand why ?
PostPosted: Fri Sep 03, 2010 9:55 pm
Send :?: to F-Secure support.
When Kaspersky hurt (boom) , I'll switch off (warn)
PostPosted: Mon Sep 13, 2010 1:24 am
i have testet v5.5,but i cant found the block privacy button,
im serching on my comp for the s7blpapx.exe but not found,
why that...? (wow)
PostPosted: Mon Sep 13, 2010 8:08 am
Install manually from
Step7 V5.5\CD_2\Optional Components\S7 Block Privacy
PostPosted: Mon Sep 13, 2010 3:56 pm
Т.е. в контроллере на флешке программа лежит уже без ключа?
И что тогда мешает сдернуть ее сименсовским программатором или картридером?
PostPosted: Mon Sep 13, 2010 6:43 pm
На флешке прога лежит зашифрованная. При считывании контроллер ее расшифровывает. Если сумеете ее сдернуть расшифрованную из памяти, то Вам повезло. ПО для дешифровки встроено в операционку. Если у Вас проц не подходящей версии, то исполнение защищенной программы Вам не светит.
PostPosted: Tue Sep 14, 2010 7:22 am
Интересно а как проц ее дешифрует без пароля?
Или пароль тоже бросается на флэш?
PostPosted: Tue Sep 14, 2010 8:20 am
Надо разбирать S7BLPAPX.EXE в http://rutracker.org/forum/viewtopic.php?t=2537609
PostPosted: Fri Sep 17, 2010 7:44 pm
Читайте про RSA-кодирование
PostPosted: Tue Jan 05, 2016 4:53 pm
У меня блоки помеченные encrypt сливаются с контроллера, т.е. в контроллере они не зашифрованы? А brock privacy устанавливаться не хочет, постоянно требует перезагрузить компьютер.
PostPosted: Tue Jan 05, 2016 7:37 pm
(sfaq) https://support.industry.siemens.com/cs/document/8861819/how-in-windows-xp-vista-7-can-you-disable-the-message-please-reboot-before-installing-any-more-programs?dti=0&dl=en&lc=ru-RU
(sfaq) https://support.industry.siemens.com/cs/document/40228606/why-do-you-get-a-prompt-to-restart-ms-windows-after-installing-step-7-v11-although-the-pc-has-already-been-booted?dti=0&dl=en&lc=ru-RU
PostPosted: Wed Jan 06, 2016 12:20 pm
S7BLPAPX.EXE это только оболочка. Используется виндошная CryptoAPI экспортируемая с Advapi32.dll, Crypt32.dll и Cryptsp.dll. Тут довольно сложно "разобрать", т.к. нужно работать на уровне ядра виндовс. Шифруется файл на карте памяти, или нет, точно не известно. Само шифрование в ЦПУ 300 или 400 затруднительно, т.к. требует значительных ресурсов процессора. Возможно только реализация на уровне железа, с аппаратно реализованными алгоритмами, как в чип картах. Все это увеличивает избыточнось, снижая надежность. Для решения возможности обойти защиту, необходим образ скаченный с карты с установленным Block Privacy v1.0, образ той-же программы без защиты, и сама программа. Достаточно программы с пару блоками, не пустыми.
PostPosted: Thu Jun 30, 2016 11:21 pm
Please help for. S7 program plc block privacy password can you help for the password ,, (sos)
https://drive.google.com/file/d/0B1R4cD ... sp=sharing
(tyou)
PostPosted: Wed Jul 27, 2016 2:03 pm
Please help me to find it.
Thanks and best regards,
PostPosted: Sun Aug 14, 2016 12:45 pm
pls i have some red blocks with password for CPU s7-319 , any help to unlock it (nuser)
any help pls send it to me by email -****
PostPosted: Tue Dec 27, 2016 9:48 am
Need help in opening the FC
PostPosted: Tue Dec 27, 2016 10:13 am
============== ADMIN ============
email will be deleted
:anon: пиши что надо со всеми подробностями
PostPosted: Tue Dec 27, 2016 10:23 am
Необходима помощь в открытии Block Privacy, наладчик который производил ПНР уволился, и ушел не совсем красиво, проект закрыт а пароль он хочет продать, руководство из принципа не идет на контакт с ним, со словами лучше заплатить другому. А я теперь должен что то сделать с этим, нахожусь меж двух огней! есть какие то варианты???
PostPosted: Tue Dec 27, 2016 10:46 am
На данный момент нет способа открыть закодированное по Block Privacy.
Как вариант можно выложить копии экранов Симатик Менеджера с перечнем функций
типа
выложить на файлообменник слитую программу или образ карты ММС... может там на самом деле KnowHow.
На мудака подать в суд... это если он работал штатно или по бумажному договору - неправомочное... вредительство и т.д.
PostPosted: Wed Mar 01, 2017 10:52 am
Hello everyone
After the function block has been encrpted, how could I unlock it?
Or is there any way to unlock the red block
thank you
PostPosted: Fri Oct 06, 2017 5:48 am
CwcPLC wrote:
Hello everyone
thank you
(no)
(no) There is no way at present
Users browsing this forum: Bing [Bot], Google Feedfetcher, krcedinac and 11 guests
