maher
Post
by maher » Tue Aug 10, 2010 11:33 am
Hallo
I was trying to upload the program from cpu siemens s7-315 2dp with profibus network but during the uploading process the follwing message was appeared
Error wrote:( uploading station to PG (13:77))
[ (2000) error while uploading the configuration to the programming device (PG) .
do you want to continue? ]
after continuing for uploading i opened the hardware configuration but i found only the empty network ( without drives or any device )
so what can i do ?
best regards
Maher
Homeroid_BL
Post
by Homeroid_BL » Wed Aug 11, 2010 10:42 am
Check adapter and connection parameters.
Umencho
Post
by Umencho » Thu Aug 12, 2010 12:49 am
I suggest to investigate to find what kind of software you don't have installed on your computer. I think this is DriveES basic. Rnf:lblSmileyTooltip_ think ...
13:77 means -
while interpreting SDBs uploaded from the module an error was recognized in the PD...
Best regards,
Umencho
maher
Post
by maher » Thu Aug 12, 2010 8:28 am
Hi Umencho
i have two cpu s7 315-2dp connected in the same profibus ,
according to your opinion , i installed the DRIVE ES ( HF1_zu_DriveES_Basic_V5.1SP1 )
after that i could make uploading for one of these cpu which is connected ( master drive, ES200 )
but the second cpu when i tried to upload it the previous message is appeared again
so what is the reason for it ?
best regards
Maher
Umencho
Post
by Umencho » Thu Aug 12, 2010 11:31 am
Are both CPU the same? Means the profibus networks content the same drives and ET200S modules. If yes could be the version of Drive ES Basic is lower then the one which was used there. If no, give details what do you have connected there?
Best regards,
Umencho
maher
Post
by maher » Fri Aug 13, 2010 3:23 pm
the uploaded cpu connected with [ profibus2 ( masterdrives , ET200S STANDARD ) AND MPI ( CONNECTED with the second cpu which has the same type )
the second the cpu connected with [ profibus1 ( ET200S STANDARD , MICROMASTERS 440, HMI SIEMENS )]
OK
Maher
maher
Post
by maher » Sat Aug 14, 2010 1:07 pm
what is your opinion Umencho?
Maher
maher
Post
by maher » Sun Aug 15, 2010 2:38 pm
Please i need help
