http://plcforum.uz.ua/
[!]: Virus inside S7-PLC, Step7, WinCC. DB 890 and DB 8062
http://plcforum.uz.ua/viewtopic.php?f=1&t=13287
Page 1 of 1
Author:  CoMod [ Tue Jul 20, 2010 1:15 pm ]
Post subject:  [!]: Virus inside S7-PLC, Step7, WinCC. DB 890 and DB 8062
Russian
Author:  CoMod [ Tue Jul 20, 2010 8:17 pm ]
Post subject:  Re: [!]: Virus for WinCC and Рreventive medicine
Clear Registry LNK tools
Start>Run>Regedit
Stop and Disable WebClient
Stop + Disable + Apply
Restart PC :(
Russia wrote:
Профилактическое лекарство
Обнулить LNK
Пуск>Выполнить>Regedit
апрет WebClient
Стоп+ Отключена + Применить
Перезапуск компа
RESULT :(
Author:  CoMod [ Wed Jul 21, 2010 9:17 pm ]
New info from Siemens wrote:
Author:  autho [ Fri Jul 23, 2010 7:07 am ]
Author:  CoMod [ Fri Jul 23, 2010 8:16 am ]
Update from Siemens
sysclean.zip
Correct: India.
It features:
s7db_open s7db_open
s7blk_write s7blk_write
s7blk_findnext s7blk_findnext
s7blk_read s7blk_read
s7_event s7_event
s7ag_test s7ag_test
s7ag_read_szl s7ag_read_szl
s7blk_delete s7blk_delete
s7ag_link_in s7ag_link_in
s7db_close s7db_close
Russian wrote:
Александр Гостев
Это функции:
s7db_open
s7blk_write
s7blk_findfirst
s7blk_findnext
s7blk_read
s7_event
s7ag_test
s7ag_read_szl
s7blk_delete
s7ag_link_in
s7db_close
s7ag_bub_read_var
s7ag_bub_write_var
Author:  CoMod [ Tue Aug 03, 2010 7:10 am ]
Author:  CoMod [ Wed Aug 04, 2010 11:20 pm ]
Post subject:  Re: [!]: Virus for WinCC and MS HotFIX KB2286198
Siemens wrote:
==== Russian ========
greg2008 wrote:
Author:  sanruku [ Tue Sep 21, 2010 3:59 pm ]
Take a look here:
& here:
for more info on the virus...
symantec wrote:
It checks:
2. Method of infection
Author:  Update [ Sat Oct 02, 2010 1:43 pm ]
Post subject:  Re: [!]: Virus inside S7-PLC, Step7 and WinCC. MS HotFIX
w32_stuxnet_dossier.pdf
Author:  greg2008 [ Wed Oct 20, 2010 10:10 am ]
Post subject:  Re: [!]: Virus inside S7-PLC, Step7, WinCC. DB 890 and DB 80
see video:
Author:  Oldman [ Thu Oct 28, 2010 6:38 pm ]
Author:  Update [ Sat Nov 13, 2010 2:22 pm ]
symantec, 11/13/2010 wrote:
Video
The PLC is infected.
• Normal operation resumes.
Author:  CoMod [ Sun Nov 14, 2010 3:29 pm ]
Who's lying?
(boom)
No one can believe :(
To Langner
Russian wrote:
Никому нельзя верить.
Отповедь руссофобу Лангнеру.
Author:  sanruku [ Wed Nov 17, 2010 11:31 am ]
Update:
Author:  CoMod [ Wed Nov 17, 2010 6:35 pm ]
KIS2011 detect all.
КИС 2011 задетектил.
About Gas Centrifuge
and
Author:  Oldman [ Sun Jan 16, 2011 8:57 pm ]
Updated: Jan. 15, 2011
Siemens security test
2008 Automation Summit
A Users Conference
How to crack PCS7
Russian
Author:  Update [ Tue Jan 25, 2011 10:58 pm ]
Author:  Info [ Tue Feb 22, 2011 11:25 pm ]
Symantec W32.Stuxnet Dossier
Version 1.4 (February 2011)
Author:  Oldman [ Sat Feb 26, 2011 6:30 pm ]
Russian wrote:
Author:  CoMod [ Sun Feb 27, 2011 12:11 pm ]
Oldman wrote:
June 3, 2002
3 июня 2002 года
Author:  CHANt [ Thu Mar 31, 2011 7:18 pm ]
Symantec in RUSSIAN
Author:  Info [ Wed Jul 06, 2011 10:50 pm ]
July 5, 2011
Russian wrote:
Author:  CoMod [ Sat Jul 23, 2011 1:36 pm ]
One year later
This is not our Cyber
but it exist
Cyber wrote:
Posted: April 11, 2008 19:27
Russian wrote:
Год спустя.
из статьи wrote:
Наш Кибер, не тот Кибер 2008.
Author:  dolphinhusky [ Wed Oct 19, 2011 8:00 pm ]
Author:  CoMod [ Wed Oct 19, 2011 10:38 pm ]
Maybe it's a reaction:
Russian wrote:
Возможно это реакция:
Author:  Schtiel [ Thu Oct 20, 2011 12:26 am ]
Author:  Info [ Sat Oct 22, 2011 10:04 am ]
Symantec
Russian wrote:
Author:  Info [ Wed Nov 02, 2011 9:06 pm ]
Author:  CoMod [ Sat Nov 19, 2011 12:05 pm ]
Then they come to you (boom)
Тогда они придут к вам (boom)
Author:  CatCesar [ Mon May 28, 2012 5:12 pm ]
See the Results
Author:  Info [ Thu May 31, 2012 1:36 am ]
Author:  Oldman [ Wed Jul 25, 2012 11:34 am ]
Russian
Author:  jpavic [ Tue Jul 15, 2014 6:02 pm ]
Virus Stuxnet
Author:  CoMod [ Fri Jul 18, 2014 7:28 am ]
Author:  CoMod [ Fri Sep 12, 2014 8:13 am ]
WITHOUT BACKDOOR
Our project is not commercial
наш проект не коммерческий
Author:  CoMod [ Sun Dec 18, 2016 1:31 pm ]
Stuxnet live anew (boom)
Author:  CoMod [ Wed Mar 08, 2017 4:00 pm ]
Pucket Putin WinCC Server :)
Author:  CoMod [ Thu Apr 20, 2017 1:56 pm ]
Post subject:  Fake news
Author:  CoMod [ Sat May 13, 2017 8:26 am ]
Global attack (boom)
Author:  DbIMok [ Mon May 15, 2017 1:16 pm ]
Author:  DbIMok [ Tue Jun 13, 2017 4:43 pm ]
Author:  tem87 [ Thu Dec 14, 2017 9:11 pm ]
Сайты антивирусов молчат.
http://www.phpbb.com/
