[?]: S7-200+TD-200 problem
MABPIK
Post by MABPIK » Thu Apr 08, 2010 1:38 pm
Have problem with 224XP connected to TD200 - "No parameter block", while in status chart I see that all VB and VW responsible for configuration match original (TD DATA 0) before download, it starts from VB0 and parameter block adress at panel is also set to 0. What else can be done. URGENT
Russian wrote:Имеется проблема с 224ХР и TD200 - сообщение "No parameter block", в status chart видно что переменные отвечающие за конфигурацию совпадают с оригинальными (до загрузки), TD DATA 0 начинается с VB0 и parameter block adress на панели тоже установлен в 0. Что ещё можно сделать. СРОЧНО
sanruku
Re: [?]: S7-200+TD-200 problem
Post by sanruku » Fri Apr 09, 2010 5:46 am
Smells like it is an TD problem. Check the TD settings (MPI address, V memory, etc...)
Otherwise, check your cabling. Do you use Profibus cable? Maybe PLC & TD are far away and you have EM interference. Try to ground the cable properly.
Usually it's a communication problem, it is rare to have faulty hardware, but you should also check your hardware.
glhf
Coyote
Post by Coyote » Fri Apr 09, 2010 1:38 pm
Or maybe you have uncheked sending of datablock in communication options.
