[?]: s7 200 analog signal is unstable
kambiz
Post by kambiz » Wed Sep 02, 2009 5:31 pm
hi
i need some advice, so help me if someone can!
i use analog input AIW0 from analog module EM235. Signal on the input AIW0 is 0(4) ... 20 mA (0...32000), but that signal is unstable!
Coyote
Post by Coyote » Tue Sep 08, 2009 10:59 am
So, what's up. You should make the signal stable, there is no other way. You can also apply filter for analog signals (see the system block).
dsekulic
Post by dsekulic » Tue Sep 08, 2009 3:12 pm
Maybe You have some interference in vicinity of measuring system. Do You You use screened cable?
xdoit
Post by xdoit » Sat Sep 19, 2009 2:01 pm
hi,
You should use STP (Shielded Twisted Pair) cable for that sensor and make sure only one end to be connect to earth.
rgds,
hsiung
