Page 1 of 1
[?]: Relay output issues
Posted: Mon May 18, 2009 1:49 pm
by reymond_craig
Hi to all,
Good afternoon I just want to ask if there's a relay output card for s7-300 that has normally close contact.
And also is there anyone here that has electrical wiring diagram for relay output card module of s7 because I'm confuse right now because I saw a document that has a 16 points relay output with only 20pin front connector.
I'm thinking that a relay output that has 16pts should use a 40pin front connector.
Thank you very much
Posted: Mon May 18, 2009 7:02 pm
by weijah
what kind of card are you using
SM 322; DO 16 x DC 24 V/ 0,5 A; (6ES7322-1BH01-0AA0)
point 1 ist 1+ 24Vdc
point 2 to 9 are the outputs 1 to 8
point 10 is 1+ ground
point 11 is 2+ 24Vdc
point 12 to 19 are the outputs 9 to 16
point 20 is 2+ ground
http://support.automation.siemens.com/W ... 0=10805256
there you will find manuals
Posted: Tue May 19, 2009 1:11 pm
by reymond_craig
Sir what i need is relay output card module manual. Thank you very much
Posted: Wed May 20, 2009 7:23 am
by venix
Hello!
Here are the manuals:
For S7-300
http://rapidshare.com/files/235077013/s ... n-US-1.pdf
For S7-400
http://rapidshare.com/files/235077974/S ... _en-US.pdf
You can use some additional relays to have NC contacts or you can program the outputs for NO.
http://rapidshare.com/files/235080041/S44EN.pdf
Best regards!
Venix
