[?]: Simotion P350 SimaticNET and OPC Server
asm_Coder
Post by asm_Coder » Mon Apr 20, 2009 6:09 am
I have problem about P350 and OPC Server.
I am using Somotion P350 SimotionP V4.1.2.3 Scout V4.1 SimaticNET2006
I can connect online by scout from my laptop to SimotionP. I can download program. After that I had Export OPC data. I had Create output file with Simotion OPC file manager. I have tried it with OPC Scout and I could see variables. Communication quality is good. I am using Ethernet interface for Communication Laptop to SimotionP.
On the SimotionP same scout and SimaticNet versions are instaled. Then I move Exported OPC data file to SimotionP and create output file with Simotion OPC file manager on SimotionP. But when I test OPC variables om OPC scout the quality communication be come BAD.
- I have tried Export OPC data in Scout as PCINTERNAL the result is same.
- I have tried Export OPC data in Scout as TCP/ETH1 and TCP/ETH2 and I did IP setting for TCP the result is same.
Also I can create a project in Scout on SimotionP and I can be come online and I can download when PG/PC setting is PCInternal(local) . But I can not make Communication OPC on Simotion P
Please idea for help,
