Pls help me!Warnning wrote:The license available is not sufficient for the configured process objects (54).
Please upgrade to another license or book the process objects in programs which are no longer necessary back to the existing license.
You can continue the download process, however.
Please see the notes in the help file.
[?] License CFC Download Warnning?
CoMod wrote:try SIFPZASRPX9999*
http://plc.net.ru/viewtopic.php?p=13428#13428
the license SIFPZASRPX9999* can not solve this problem
should not you encounter this problem?
My PCS7 version is PCS7 sp1 ro sp2 chinese.
Process Control System PCS 7 V7.0 SP1
PC Configuration and Authorization
https://support.automation.siemens.com/ ... _en-US.pdf
p.120-122
CFC Problem with PO license....
In Logs windows after Chart compile is ready at Download tab I recive an error and at details i recive this text:
What to do?!
"More POs are needed for the program to be loaded that are currently available in the ALM.
The program is still loaded but the error state is noted.
Once the licenses have been increased, the POs marked with this error state are included in the booking during the next download.
You can find detailed information on PO licenses under
Counting and Booking PO Licenses "
What to do?!
Re: CFC Problem with PO license....
do screencopy of PO statistic and ALMgabitzu6 wrote:What to do?!
