[?+]: Tia Portal Updater not work
emos
Post by emos » Wed Aug 15, 2018 7:09 am
Hi friends
TIA updater message "unable to connect to the server" appears. I have antivirus and firewall disabled. The result is the same.
Does anyone have any idea?
Regards.
anorexia
Re: Tia Portal Updater
Post by anorexia » Thu Aug 16, 2018 5:39 am
company, router policy can block it also. Norton intelligent file protection also blocks it.
emos
Post by emos » Thu Aug 16, 2018 10:42 am
anorexia wrote:company, router policy can block it also. Norton intelligent file protection also blocks it.
I tried home and mobile phone use internet connection, but same problem.
Post by CoMod » Thu Aug 16, 2018 4:07 pm
Tia Portal Updater v14 SP1 work without problems
emos
Post by emos » Fri Aug 17, 2018 9:59 am
CoMod wrote:Tia Portal Updater v14 SP1 work without problems
I have the TIA V15 and V13 installed.
I ran the repet setting from the Simatic security control program.
but the problem continues
Simko
Re: [?]: Tia Portal Updater not work
Post by Simko » Fri Aug 17, 2018 1:20 pm
Start Tia portal updater as Administrator (Run As Administrator). (pgood)
emos
Post by emos » Fri Aug 17, 2018 1:31 pm
Simko wrote:Start Tia portal updater as Administrator (Run As Administrator). (pgood)
I tried, nok.
emos
Post by emos » Wed Aug 22, 2018 11:38 pm
my makeshift :) solution at below link
TIA Updater Corporate Configuration Tool
https://support.industry.siemens.com/cs ... 0&lc=en-US
Answers to FAQs
Re: [?+]: Tia Portal Updater not work
Post by Answers to FAQs » Thu May 14, 2020 9:27 am
for correction of this problem install TIA Administrator from here : https://support.industry.siemens.com/cs ... iew/114358
