[Request] Wincc Advanced V14 Runtime
ricc
Post by ricc » Wed Feb 14, 2018 10:20 pm
Hello to all, someone can posted a link for Wincc Advanced V14 runtime?
Thanks (oo)
optoel
Re: [Request] Wincc Advanced V14 Runtime
Post by optoel » Wed Apr 25, 2018 11:36 pm
Hi to all,
I also need this.
WinCC Runtime Advanced V14 SP1 won't install without havingWinCC Runtime Advanced V14 installed first.
Or there is a way to install SP1?
Please reply if you have any info on this.
Rex2701
Post by Rex2701 » Thu Apr 26, 2018 12:15 pm
You can block unnecessary SP1 requirement in InstData\Resources\SIA2.ini
Find next string in the file:
{Registry};{HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\Automation\_InstalledSW\HMIRTM_V11\RT_Adv\Release};{REGSZ};{>=};{14.0};{TermMessage29};{1}
and put a semicolon in front of it. Like here:
;{Registry};{HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\Automation\_InstalledSW\HMIRTM_V11\RT_Adv\Release};{REGSZ};{>=};{14.0};{TermMessage29};{1}
optoel
Post by optoel » Thu Apr 26, 2018 12:39 pm
Yep, it works. Thank you!
