Thanks for the info
Have I checked and I see no solution, because I have about a hundred projects.
I will not do the updates all CPU's, and other modules.
I am saddened by this new Step7 V11
End my opinion is not compatible with Step7 V5.5
additional testing I've done by changing the cpu, after the migration appears dozens of errors.
Migration date: 5/21/2011Type Message Time
Migration log 11:30:42 PM
Station: SIMATIC 300 11:30:43 PM
Hardware configuration 11:30:43 PM
PLC program 11:30:43 PM
Objects to be migrated 11:30:43 PM
Organization blocks: 3 11:30:44 PM
Function blocks: 6 11:30:44 PM
Data blocks: 55 11:30:44 PM
Functions: 28 11:30:44 PM
Data types: 1 11:30:44 PM
Tags: 1661 11:30:44 PM
FB2: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC6: The interface of DB10 is out of date. 11:30:43 PM
FC1: The interface of DB10 is out of date. 11:30:43 PM
FC19: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC23: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC50: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC51: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC52: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
FC70: The interface of DB80 is out of date. 11:30:43 PM
FC80: The interface of DB80 is out of date. 11:30:43 PM
OB1: The interface of DB70, DB71, DB72, DB73, DB74, DB75 is out of date. 11:30:43 PM
OB100: The interface of DB10 is out of date. 11:30:43 PM
The classic project is not consistent. "Programma S7" needs to be recompiled. 11:30:43 PM
FC1: The data type DB18, DB20, DB22, DB24, DB26, DB28 is unknown. 11:30:43 PM
CPU 315-2 DP\FB41: The corresponding SCL source is missing. 11:30:45 PM
CPU 315-2 DP\FB101:The label name "'ok'" is not unique. Label renamed to "'okä'". 11:30:45 PM
CPU 315-2 DP\FC101:The label name "'ok'" is not unique. Label renamed to "'okä'". 11:30:50 PM
General 11:30:43 PM
Error during migration. 11:30:50 PM
This only changed the hardware virtually
flopez
